Ive got a Kustom 200B im trying to figure out. It has power but no output.
power board is the pc703
Here is what i have found so far :
No voltage to the 2 preamp boards. should be 8V there.
power from the 2 huge caps is 40V and is at the power board.
Found 1 burnt resistor, R746, replaced it. No change.
The 5 diodes all test ok in circuit.
The schematic has the voltages on it so i went down the line on all the transistors.
the 4 main output transistors all have correct voltages at the legs.
that would be Q1,2,3,4 .
i have a hard time tracing when there are this many transistors going on...
so i will list what i found on each one , maybe someone with the scem can help me trace it ?
Q701 0v , 0v , 0v (0 = meaning 10-100 mV )
702 17V , 0.6v , 0v
703 17v , 23v , 18v
704 ok
705 0v , 0.6v , 38v
706 1v , 0v , 0v
707 0.6 , 0v , 0v
708 OK
709 0v , 0.6v , 38v
710 0v , 0v , 0v
711 0v , 0v
712 0v , 0v , 38v
713 0v , 0v ,0v
714 0v , 0v , 38v , 38v
715 0v , 0v , 0v
716 0v , 0v , 38v
717 0v , 0v , 0v
718 0v , 0v , 38v , 38v
i hope that makes sense - if you look at each tran. on the schematic it might...
702 17V , 0.6v , 0v
703 17v , 23v , 18v
704 ok
705 0v , 0.6v , 38v
706 1v , 0v , 0v
707 0.6 , 0v , 0v
708 OK
709 0v , 0.6v , 38v
710 0v , 0v , 0v
711 0v , 0v
712 0v , 0v , 38v
713 0v , 0v ,0v
715 0v , 0v , 0v
716 0v , 0v , 38v
717 0v , 0v , 0v
