peavey delta blues ?
  • peavey delta blues ?
    hello everyone, im new to the forums and i have a few questions that im not quite sure of and would appreciate your advice.
    i bought a used delta blues amp the amp sounds nice no real trouble as of yet. and was wondering,
    1. does tubes have a manufacture date on them?
    2. the preamp tubes do not glow as bright as the power amp tube's.
    3. there is a static sound like a radio not tuned to a station not loud though has to be turned up really loud to be very noticeable i thought this might be normal.
    4. does this type of amp need matched power tubes because it is fixed bias or is it just suggested
    the preamp tubes are 12xa-lps sovtek with the numbers 99 11 at the bottom thinking this might mean Nov 99 if so those are some long lasting tubes.
    i am new to owning a tube amp but have done some searching before asking these qestions. so these questions maybe very noob type questions
    thx for your reply's fret.
    Noise like that I'd suspect as a tube problem 1st and solder errors 2nd.
    Lightly tap the tubes one at a time with a chop stick to see if any make noise or static or excessive microphonic ringing.
    Loose ground or solder on the input jack can cause some static noise as well.
    casinolevant levant casino
