Does anyone know the color codes of the OT secondary on a MIG100? They don't seem to match what I have seen in Marshalls. Someone has made some sloppy solder joints on these jacks already and I just want to be sure that they have poorly but correctly connected these jacks.
MIG100 - Replacing output jacks
"The time I burned my guitar it was like a sacrifice. You sacrifice the things you love. I love my guitar."
- Jimi Hendrix
http://www.detempleguitars.comTags: None
OK, so it's not a veritable jewel of antiquity, but if it were your only car you would drive it too.
So here is what's on the secondary for the MIG:
GRN 4ohm
WHT 8ohm
YLW 16ohm
BLK com
And a Marshall (2203):
BLK 4ohm
YLW 8ohm
GRN 16ohm
BRN com
There appears to be no color correspondence that I should be concerned about. I will swap the jacks just as they are and test it out."The time I burned my guitar it was like a sacrifice. You sacrifice the things you love. I love my guitar."
- Jimi Hendrix
Hey, thanks. I do have the schematic, but it doesn't show the wire colors. In any case, I connected the outputs and they work, but the amp is sounding weak. Clearly there is something else that the owner did not mention. I do believe the wire colors are correct as I listed them. This thread may be the only resource on the web for that info."The time I burned my guitar it was like a sacrifice. You sacrifice the things you love. I love my guitar."
- Jimi Hendrix
