Fender SK 100B pre amp section out
  • Fender SK 100B pre amp section out
    I have a Fender SK 100B that has no output from the pre amp section. I can plug into the power amp input and get sound out. Does anyone have a Schematic for this?
    I got one late today from Fender customer service
      Fender schematic
      Can you post the schematic for all to see?
        fender schematic
        Sure. I've attached the schematic. I'm getting audio out now. I found a ceramic disc cap with long legs that was bent over and shorting to a resistor. Someone must have been in this amp before I got it. Now I need to test all of the front panel controls to see if everything is good. What's a good source to plug into the input to check the tone,gain,volume ect. ? I've been using an MP3 player.
          Test Input Source
          Best?
          I use a frequency generator with an adjustable amplitude.
            singal generator
            I'm going to try a PC signal generator program I found.
              PC signal generator
              That will work.
              Watch the amplitude Remember, a guitar puts out anywhere from (avg) 80 to 120 mvs.
