I recently re-capped, and added a 3 wire power cord to a Fender VC. I wired it according to the schematic, and it all works/sounds fine. But I am confused. I am use to running a wire to Pin 2 and 7 of the power tubes, and a wire to Pins 4-5, and 9 of the pre tubes. What is the reasoning behind the VC scheme?
On the power tube the heater goes to Pin 2 and Pin 7 goes to ground. The pre tubes get a wire at Pins 4-5, and Pin 9 goes to ground. Can one of you guys explain this difference to me?
Thank You
http://www.ampwares.com/schematics/c...ibro_aa764.pdf
Thank You
