Have a MG100HDFX for repair. It won,t switch to clean channel. The channel switch indicator does not go on/off when pushing switch button. I do not have the footswitch for this amp either. I am not up to par on this solid state stuff. I AM striving to learn though! Amp plays,but does not have the 'balls' that I would expect from a Marshall. I have read and re-read prior posts on this amp and it seems to me that it has a lot of problems....heat-related,chips,etc. Possibly a bad design to start with!
What is the function of the green/red led's mounted on the PCB as far as diagnostics?
The heat sink fan on this amp makes a whining noise for a minute or so on start-up, and then smooths out and quiets. Normal? I have cleaned some dust from around it,although it was not extremely dirty.
Hopefully, someone can call out some part #'s that would be suspect on the board. Thanks and I hope I am not wearing out the subject on this amp. Rod
