repaired one of these 400 bh previously thanks to
this forum many thanks for the great help
this problem is another peavey mark 111 bass amp I have that is not working
400 bh board produces no output
I changed a shorted out power transistor q9 with new mje15003 ,tl074,two 4148 diodes
and a p600 diode i
used light bulb limiter
amp powers up ok
checked all cement resistors none are open
removed u2 no effect
tested preamp it is ok
vr's seem to be working 15 volts out
no hum when touching connector at corner of board
getting voltage at output transistors 51 volts rails
low voltage .02 at q6,q5 and q4 but q3 reads correct
any one have any ideas as to possible culprit for no output and the low voltage readings
thanks in advance
regards
robgrif
and a p600 diode i
amp powers up ok
thanks in advance
regards
robgrif
