I'm new to this very informative site so Hello-and thanks- to all. I wondered if anyone could help with a problem I've just experienced with my jcm 800 2X12 100W reverb combo. Clean channel working OK. But, when you switch to the "boost" channel, suddenly instead of a lift in volume and some nice crunchy overdrive, you get a muted mush of reverb (which is actually switched off!!) and as much distortion as a Dalek speaking through a fuzz box. I should say this doesn't happen immediately- the amp needs to have been on a while for it to occur.
I've had the amp about 14 years- but I haven't owned it from new. It's had only occasional use for many years but now I need its services again on a regular basis, it seems it is not equal to the challenge. The output valves were all changed together ages ago (to Siemens- I didn't have it re-biased, I know naughty naughty-but it's always worked ok) but all the pre-amp valves are of unknown age and origin. I have already cleaned the effects loop sockets as these have caused probems in the past, and I've re-seated and swapped round the valves, but to no avail. Does any one have any ideas where I might start looking-new valves, for example? All suggestions/ideas welcome. Ta
