Hello All: I'm a brand new member due to Googling my problem:
I was set up to play a gig a couple of nights ago with my band. I switched on my HRD as usual. The red light came on, then after 30 seconds I switched on from standby. No sound.
After messing with it (under pressure) onstage for a couple of minutes, I gave up and used a spare amp as it was time to get on with it. I did not start looking to see if all the valves were lit at the time. Later that night when I got it home, I checked the internal fuse was ok, and switched the amp on. All the valves lit up. All working ok!
I've had the amp for about four years, has never been messed with at all, and has probably done about 100 cycles of 2 hours. Unfortunately I had an amp stand collapse a few weeks back, and it horrifically dropped about 4 inches to the ground, and onto it's back. It did not stop then, and it has been used a number of times since with no problems. The amp (apart from the accident) is treated gently.
I've read some comments about plugging in the wrong jacks (which I don't think I did), overheating resistors etc. which seem to associated with performance problems rather than on or off. Now, it could just be me being dumb, but I don't think so. Has anyone got any ideas?
