I have a Fender Frontman 15g. I got a blown fuse after using the the aux input and the headphones at the same time. I was experimenting with the aux because whenever I used it, the volume would be maxed out and wasn't adjustable. From what I've now read using the aux can cause problems with this amp.
After a couple more blown fuses, I tried replacing the output ic (tda 2050 and U4 on the schematics) and the amp worked again for a few minutes. I then shut it off to put the whole thing back together again. When I turned it back on all I got was a buzz, so I took it apart again to see what was going on. When I turned it on the fuse blew so I think the ic was toasted again.
Any help or advice would be great because I really don't want to have to buy another amp and I'm determined to get this fixed.
