I'm recapping a 67 BFPR and replacing resistors when I find them out of tolerance. The fiber board had several eyelets with multiple components and lots of solder. I carefully removed the old components and used a spring loaded solder sucker to remove the solder. I am worried however about what I cannot see; the under side of the board. As you know, the board is actually two boards sandwiched together and I'm wondering how clean it is under there. Anyone ever have a problem with this? Should I try to lift it up a bit to inspect it (it's wired pretty tight) ? Thanks, frank...
Old Fender fiber boards
If the boards are relatively flat, not bowed, and sit pretty flush together I'd say that you are very unlikely to have a problem. Work carefully & keep using the solder sucker. Don't drown the eyelets with masses of new solder.
Some old Fenders (particularly, it seems, 70's SF amps) can have very warped boards, with a lot of air between the circuit board & insulating board, then you can sometimes have drips shorting eyelets, but if the board is very warped then this is easy enough to see & remedy.
If it's easy enough to lift the board then do so, but mostly I wouldn't worry. There's more chance that the board itself can become conductive and bleed voltage between eyelets. In either case, if there is a problem it will be audible - ticks & pops as voltage leaks from areas of different potential, sometimes a wooshing sound like waves on a beach..
The boards are relatively flat, not bowed, and sit pretty flush together. There is a little bit of warp but not much. Thanks for the advice. I really appreciate this forum and the ability to bounce ideas off of more experienced builders and techs!
Oh the JOY of turning on an amp the first time after major work and NOT having it blow up, smoke or otherwise deflate your fragile ego!!! I fired up the Princeton last night (slowly) - I used a light bulb short circuit (homemade) tester and started with all tubes pulled. It works! After several minutes, I plugged in and wasn't exactly happy with the sound. It had a heavey, flabby base to it. I turned it off and went for a walk. I didn't get far when I realized that I had connected the reverb pan incorrectly. I had connected the rca cords from the amps reverb out to the pans output and the reverb in to the pans input - out to out, in to in right? Go figure... Well thankfully, I didn't hurt anything and all was well when properly connected. Being "new" to reverb circuits, I did notice and wonder why the 12at7 reverb tube glows more brightly than the other preamp tubes. Is this because it is more of a current amp verses a voltage amp or am I missing something? As always, I appreciate the wise responces. frank
The 12AT7 may simply glow more (we are talking yellow points of light, not the usually grey/black plates glowing red/orange) because the internal structure allows the heaters to be more visible? It is usually run off a much higher voltage supply than the preamp tubes, and "yes", it draws more current than a 12AX7 would do in the same circuit. Essentially the 12AT7 is acting as a little SE power tube, driving the reverb tank, rather than a speaker.
In short, 12AT7 reverb drivers run hotter than many other preamp tubes & I doubt that the glow you see is a cause for concern.
BFPR bias adjustment
One of the things I noticed after removing the vibrato circuit and tying the bias wire directly to the pwr tube grid resistors is that the bias voltage went to -36.7 vdc from the -34 vdc before the change. I didn't worry about it because the idle current seemed fine at 31 ma. However those values were obtained with the adjustable cathode resistor (see earlier post) maxed out. I was wondering if anyone knows what value of bias resistor would bring that back to -34 vdc. It is currently stock at 100k. I have 120k and 150k on hand. The "removed vibrato pot was 250k linear. Thanks
Originally posted by frankeg View PostOne of the things I noticed after removing the vibrato circuit and tying the bias wire directly to the pwr tube grid resistors is that the bias voltage went to -36.7 vdc from the -34 vdc before the change. I didn't worry about it because the idle current seemed fine at 31 ma. However those values were obtained with the adjustable cathode resistor (see earlier post) maxed out. I was wondering if anyone knows what value of bias resistor would bring that back to -34 vdc. It is currently stock at 100k. I have 120k and 150k on hand. The "removed vibrato pot was 250k linear. Thanks"In theory, there is no difference between theory and practice. In practice there is."
- Yogi Berra
Bringing it back to -34v will bring the plate current up (hotter than 31mA). I would only run 30mA per tube with sturdy NOS tubes or maybe JJ6V6. I wouldn't be keen to run much more than 30mA per tube with any 6V6 tube. I don't know why you want -34v specifically, negative voltage is only a byproduct of plate current (which is the critical perameter).
I would adjust the plate current by changing the value of the 27K grounded resistor after the bias diode (add a 10-20K trim pot, wired as a variable resistor, in series with original resistor to ground), rather than change the 100K.
The amp sounds fine where it is. I was just wondering. I certainly could be wrong here (have been before) but I thought you could bias 6V6's between 30 and 33 ma. Does that assume nos tubes?
I like this idea!!!
Thanks for the quick responces... I appreciate it.
"I certainly could be wrong here (have been before) but I thought you could bias 6V6's between 30 and 33 ma. Does that assume nos tubes?" You can bias them to 50-60mA if your plate voltage is low enough - DON'T try it in a Princeton though, the voltage is way too high!
Fixed bias amps are usually biased anywhere from 50-80% of plate dissipation (14W in this case), 70% is considered the typical max, unless experience shows otherwise. At say 425v (?) @ 31mA you will see that your plate dissipation is around 13W per tube (92%), that's pretty hot already. Plate voltages over 425v may be detrimental to NOS 6V6, so it's up to you whether you bias cooler & run the tubes way over voltage (not an issue with EH & JJ6V6, they can take more volts), or run high current at lower volts.
Cathode biased amps may be biased more like 80-100% plate dissipation, sometimes higher for SE 6V6 designs like Champs.
