A moderately large number of the posts to this forum fall into the two classes of
- " My (insert amp here) blows fuses!"
and
- " My amp is dead. It's the transformer, isn't it?"
Both of these are going to (or should ) get the same response every time. For the first, blows fuses, it's going to "build a light bulb limiter to quit blowing fuses so you can debug what the problem actually is".
For the second it's "No, it's most likely not your transformer. It's the transformer only in some fairly rare instances."
As a bit of meta-advice, any time you have an urge to post to any forum about a problem you're having search the forum before posting. You may well find the answer to your problem faster than you would by reciting the symptoms in text.
and
