I bought the Fender 'Twin Amp' from a shop and it was nearly new. Not long after, it began blowing fuses. This fuse lies in an in-line fuse holder on one of the wires coming from the transformer and connects via a spade connector to the circuit board; this wire is Green and the place where it is supposed to connect to the board is clearly marked VERD/GRN. However, after it has comes through the PCB, it is connected to a RED wire by means of a male-female spade connectors and this red wire carries the in-line fuse. Late last year, the fuse blew again but this time, the in-line fuse holder melted and had to be replaced. It is rated at 10amps.
Having read a few amp repair and modifying books by some well known authors, I decided that the problem that I was having with my 'Twin Amp' was being caused by a/some problematic axial electrolytic capacitors so, I change all 9 - 5 rated @22/500 and 4 rated @47/350.
The problem? After being on for approximately 1.5 hours, the power transformer becomes so hot that you cannot put your hand on it or within an inch of it.
All valves, both 7 pre and 6 output have been changed twice in the last few weeks, all to no avail and the bias has been twice set correctly also.
Anyone - any suggestions?
Regards Tom
Regards Tom
