What's happening fellas? Well I have a Vintage Club 50 here, brought to me with the clean channel not working and a VERY WEAk OD channel. I fixed the clean channel no problem- the footswitch jack just needed to be cleaned.
All the tubes are fine, I've been reflowing a lot of the solder joints. I tried putting an insert cable w/patch cord into the effects loop jack with no luck there. That actually brought down the signal on both channels.
I got some interesting results at a few of the test points in the pre-amp section. At T.P. 1 I got 180.3VDC(clean) and 184.4VDC(OD). Seems ok. But at T.P. 2 on the clean channel I get 235VDC and 180.7VDC(ODchannel). I'll post some more of the findings in a bit as I have to run but if anyone could shed some light here I would greatly appreciate it.
Scematic:
http://www.blueguitar.org/new/schem/...ge_club_50.pdf
Scematic:
