A Conundrum of Sorts
Well, what an interesting journey this has been. I replaced all of the filter caps as well as the bias cap (100uf). There was a loud hum at first but that went away. Things started to settle down so I plugged in a guitar. The guitar came through fine. Some of the pots are a little scratchy and I intend to get back to them later. They were not terribly scartchy. Just a little scratchy.
There remained a slight hum which went away with the volume knob so my guess is preamp circuitry as the culprit. I figures "ehh... so far so good, as I go through and learn this thing I will eventually replace whatever is causing the hum.
Now for the interesting part (depending on how you look at it I suppose), The tubes are glowing with a bright color orange. Too hot for my taste and based on my limited experience with the few tube amps I've owned, way too hot for normal operation. So now, it's time for me to check the bias. I go to check the bias and not many of my readings a making sense to me. I'm using a couple 6L6's from an old Plush Amp that was given to me. The tubes do not appear in that bad of shape. The original tubes were RCA's with some noticable arcing on the sides of the tubes (inside the tubes) so I tossed them.
The 470 ohm resistor and diode next to the bias filter cap check out to be ok.
I set my meter to DCA 200 mA range, put one lead at center tap (What I believe to be B+) of the OPT and the the other lead to pin 3 of one of the power tubes. The amperage gets higher and higher and higher. I had to change the range on my meter to get a final reading of .350 AMPS?? OMG! I think to myself. What have I done? Now remember, the guitar was coming out of the speaker just fine. I must be missing something. There are two tubes so I am reading half of the OPT's output, but still 175mA's?
I change my meter to the 1000v range and check the voltage from pin 3 of a power tube to ground. 450-460 Volts DC.
No matter where I place my meter and however much I tweak the bias pot I see no change on the large OPT current between B+ and pin 3 of a power tube.
I disconnected the wires and checked the resistance of the bias pot and the resistor going from the 3rd lug to ground. Everything ohmed out fine. Same with the two resistors on the bottom of the power tube sockets. I get the sense that I am missing something here.
Finally, I decided to try a couple different tubes so I pop in a couple realistic 6L6's out of the afformentioned Plush amp and observe...
Their warming up... I'm watching the milliamps... their climbing... 150...160... one of the tubes is starting to glow... then... the milliamps started going down... down further ... that's when I realized that the fuse had blown
Anybody, anything?
Anybody, anything?
