Soul head that will not power up - doesn't blow fuses. The front panel red LED that indicates some type of fault has occured flashes briefly before relay trips power.
Power supply rectifiers check out, all caps check out and all output devices pass simple check with DVM. The PCB is a mix of SMT and through hole (might also be a lead-free assembly).
Anyone ever work on one of these? Don't have a schematic for the power supply section...
Soul0105.pdf
Soul0105.pdf
