Yea another hum thread. I just replaced all caps and resistors in this amp (1940 Gibson EH-150) and the amp is alive and plays well but there is a hum. I dont know if hum was acceptable in the 30's and 40's. Volume does not change hum. I replaced the 2 prong plug with a grounded plug. I pull the first tube-no change, second tube-no change, third tube- no change, fourth tube-hum goes almost completely away, barely audible. I try all the tubes in the 4th position and each one brings back the hum which takes the 6c5's off the list of possibilities. I pull the wire from pin 3 of v2and3 and the hum goes away. So why didnt it go away when I pulled those tubes?
Next on geofex hum possibility list: mismatched output tubes-I used 2 seperate pairs of matched tubes and no change in hum.
Next-Bias Supply Caps-No caps cathode biased
Next-Unbalanced Filament winding-There is a CT which is grounded, perhaps I should put in the faux CT
Next-Input Jack-they are grounded to the chassis but if removing V1 or V2 doesnt change it then it cant be the jacks
Next-Poor internal wire routing- Perhaps but it is the original wiring
I am ready to update this sucker with all new wiring but I dont want to. Could it be a tranny problem? or do you think it is probably a grounding problem?
I have included a pic of the innards. The tag board has all new parts but everything else is the same.
