Hi guys,
Been away a long time... feel remiss in not being around and contributing, but been ill and out of the game for a while... but wondering if I might ask a question here:
Have this Frontman 15G with an excessive hum, without anything plugged in. Volume control doesn't affect it much. Sounds either 60 or 120HZ, not sure which. When I touch both the ground sleeve of the input cord and the metal handle bolt (connected to chassis I guess) the hum drops dramatically.
Checking for AC voltage between the input ground and the handle bolt, I get like 3VAC on the DVM (while not doing the grounding thing above).
Other than the hum, the amp seems to function ok.
The schematic says there is no connection from earth ground to electrical ground. I don't quite understand this sort of design, and how is it supposed to work properly anyways? Any ideas? Can I just connect a cap from earth ground to electrical ground and call it a day?
Thanks,
Chevy
Thanks,
Chevy
