I own a Peavey Bandit Transtube 112 amp which has a 2 button footswitch. One button switches between two channels, and the other turns the boost on and off. The same pedal is used by Peavey on other amps and the second button activates the reverb on the other amps.
Anyway, I tried to add LEDs to the footswitch. This is what I did .... I measured voltage at the switch and got 15 volts.....I then went to Radio Shack and bought LEDs that were rated for between 12 and 16 volts, and intalled them....the LEDs worked, but the switch did not activate the functions it was supposed to....I then measured resistance and got about 1.7 on each LED.....
Can someone help me out with this......I am not electronically inclined.
The Peavey switch part number is 5436.
