So, I used the effects loop to determine that the preamp is good and the speaker is good, but the power amp is not.
I pulled the power amp board and IC1 (TDA2050) is burnt. Three of the leads are scorched and the case is cracked open. The board, where IC3 (7915A) attaches, looks blackened. The board at IC2 (7815A) is a little dark too.
OK, IC1 is done and needs to be replaced. IC2 and IC3 have clearly been very hot at some point. They both need to be pulled and tested, but the parts are cheap so I'll probably just replace them too.
Question: Why would these components burn up? Is there something else I need to be looking at?
Question 2: I don't find any transistors on the Mouser site that are just numbered 7815A or 7915A. They are more like: KA7815ATU or L7815ABV. The examples I named both have different specs. How do I know what to get?
Thanks, Shannon
Thanks, Shannon
