Has anyone ever encountered this - a speaker that only works sometimes? I thought a speaker is either blown or it isn't. The speaker in my recently purchased 73 SF DR has this problem - it seems to work again for a while after I smack the magnet in the back, but then stops after a couple crackles. I've checked the solder connections at the speaker and at the 1/4" jack and they're all OK.
I have plugged an external cab with a single 12" speaker in as a replacement and the amp works fine so I believe that it is the stock speaker.
By the way the external speaker I've used sounds great but it's a 16 ohm Celestion. Can I use it as a permanent replacement or will this cause too much strain on the amp?
