I was just comparing amps for a gig tonight and I noticed the SFDR is (re)producing a lot more buzz from my single coil Tele pickup than the Bassman.
This is not 60cycle hum, and I don't think it is poor power supply filtering, because it is mostly a HF and hi-mid sound sort of a combo of white noise and static, the kind of noise generally cause by badly filtered lighting etc. getting picked up by the guitar.
Same guitar, same cable, side by side in same room, and I tried the SFDR through the spkr the Bassman was in to make sure it wasn't just HF roll-off by the speaker that made the difference. Both amps have 3-wire AC cables.
NOTE: the SFDR has been modified with a switch to select solid-state or tube rectifier. This switch was put in place of the AC polarity switch. There may be no RFshunt cap in the amp anymore, I don't recall. Also the "bright" cap on the 2nd channel has been moved to the switch of a push-pull pot and was not engaged at the time.
Full disclosure: The Bassman has been modified to run EL34s. The SFDR has been more modified to run Rev and Vib in both channels, the pre-amp stage cathodes are all de-coupled, and it is running 6L6s.
