Hi, I built a 5F6A Bassman, with help of this layout:
http://www.ceriatone.com/images/layo...one_100508.jpg
All is working fine; now I wanted to bias the power tubes. Never done this before. So, I need a little help.
I use JJ 6L6GC's. The datasheet says the maximum plate dissipation is 30W.
http://www.jj-electronic.com/pdf/6L6%20GC.pdf
I allready did some measurements.
With the bias pot at minimum I have
Anode Voltage: 445V
Cathode Current: 18.8mA
So, plate dissipation: 8.4W
With the bias pot at maximum I have
Anode Voltage: 417V
Cathode Current: 50mA
So, plate dissipation: 20.85W
I checked with my guitar, and to be honest, I didn't hear a difference between different bias settings. (I did hear an increase in noise, with higher cathode current) What kind of difference should I hear?
What is the most common bias setting? Very near the maximum dissipation of the tube? (not really possible, because the max I can get is about 21W)
Another question: For matched tubes, the cathode currents should be as close as possible, I assume? How many milliamperes may they differ, to still be considered "matched"?
(I measured them both with the minimum bias: 17.3mA and 18.8mA)
Thanks!!
Anode Voltage: 445V
Anode Voltage: 417V
Thanks!!
