Hi Guys,
Two unrelated questions on the SVT-5 Pro. I'm using bridged power amp mode here.
1. I've got a background mains hum which is there no matter what knob I twiddle. What kind of ripple should I be seeing on the high-voltage power amp rails? With no load and no input I'm seeing 300mV pk/pk of ripple on each rail. Seems a lot to me. Is that normal or are my jumbo smoothing caps knackered? I've checked the bias of the easy-to-reach power amp stage per Ampeg specificaiton and it looks good. Does the power amp just pull lots of quiescent current or should I be worried about those caps at that ripple level? Do they just hum because they are mega high-power amps and consume lots of quiescent with the whopping great output stages?
2. Perhaps a generic toob-noobie question, what are the characteristics of a knackered/aged pre-amp tube? I have some odd low-level high-frequency distortion/buzzing, the frequency of which seems to be unrelated to the input signal frequency and which seems to be related to the gain at the very first stage of the amplifier - possibly the tube. Turn the first stage gain right up and it goes away/is masked by the noise floor, same with right down. Seems to come straight through to the speaker no matter what the gain level of the master gain is. Not a problem at high volume levels, but is a pain at practice levels.
Any guidance very much appreciated!
Cheers,
Grant
Cheers,
Grant
