I've got a homebrew here that I'm tweaking, the PT was originally running a pair of EL34s and three ECC83s - I'm using a pair of 6V6s instead and the heater voltage is a bit on the high side (7.65vac).
How can I drop the voltage down without introducing any 'sag' into the amp?
Can I use a zener diode between the heater tap CT and ground? I'd only be needing a 1v zener at ???watts right?
