Cant seem to figure this one out......Soldano designed Yamaha T50C
  • Cant seem to figure this one out......Soldano designed Yamaha T50C
    I just copied and pasted my post from TGP. Maybe one of you dudes have some suggestions?
    I purchased two identical Soldano-designed Yamaha T50C 50 watt combos. The amps are pristine in and out and havent seen any road/heavy use in their life. These amps still had the original tubes in them as well. Basically I started with one of the amps and swapped some of the preamp tubes out until I got it sounding awesome.
    I then moved on to the next one. It seemed to be really tired sounding on the clean channel and when you switch to the drive channel you get a slight hum and hardly any volume. I did what seemed logical and swapped all the tubes from the one I had up and running really well, but to my surprise the issue remained even with all known good tubes. One other very interesting thing is that on the clean channel the more you crank the reverb the louder the amp gets and the verb get SUPER wet as well.
    I have visually inspected all the caps inside and they all look fine (no bulging or leaking). I also didnt see anything else that looked odd to me.
    Check this video I just shot of the issue. The volume I have the amp set at should blow my face off, but as you hear it doesnt. Also notice the verb gain thats added. The other amp doesnt act like this whatsoever as verb is turned up.
    YouTube - Yamaha Amp
    Any tips fellas?
    you have 1 working and 1 not; its the perfect case for A/B testing. I'd carefully test the voltages at the sockets and see where the difference lies. My guess is a bad cap thats not obvious that hurts the power tubes or maybe early preamp stages. Can you take pre out and power in and mix the amps?
    Be sure about safety/ cap bleeding/ chopsticks etc before running them open!!
      How old is this amp/filter caps?
      https://www.youtube.com/watch?v=7zquNjKjsfw
      https://www.youtube.com/watch?v=XMl-ddFbSF0
      https://www.youtube.com/watch?v=KiE-DBtWC5I
      https://www.youtube.com/watch?v=472E...0OYTnWIkoj8Sna
        Check the resistors, there was one that went out on my T100 that showed similar symptoms. I believe in my case it was the one that went across V5 (Tone Driver) tube. I read a post from Jerry P from fjamods where he said that he had some come in to his shop with the similar resistors out on the T series amps.
          we have a winner! Damn, real knowledge again beats my rectal wisdom...
