Ampeg B2
  • Ampeg B2
    On the bench again we have our very favorite type of repair: an Ampeg-by-Crate bass head.
    Symptom: instrument signal is very faint and very distorted (the distortion actually sounds kinda musical, kinda hard rockin').
    Gets a clean sine all the way to the Preamp Out jack.
    Running a 1K 1V p-p sine into the Power Amp In jack, it's fine until IC4 pin 7 (test point 6 on the schematic) where it is a 30V square wave.
    Here is the schematic of the section I'm talking about:
    http://www.euthymia.org/image/42704h0.pdf
    Any ideas? I've replaced IC4.
    -Erik
    Euthymia Electronics
    Alameda, CA USA
    Sanborn Farallon Amplifier
    It could be a shorted output or bad output transistor (the "greatest hit" of SS amp failures). An output short would remove the NFB from the "OUTPUT - see sheet 2" node, causing stage IC4b to have a lot more gain and probably hard-clip.
    Ray
      Thanks, Ray.
      I probed all the MOSFET's in-circuit and they measured the same; pulled one and it was fine, so I concluded that they were probably okay. Usually they fail to a dead short.
      So that is a NFB loop going back to IC4. I'll check that to make sure the signal is making it. I'll also check to see if something's shorted across the output.
      -Erik
      Alameda, CA USA
        FOrget NFB, what about DC levels through the amp. What is at TP 7,8,9,10? The two input transistors of the power amp on page 2 need +/-16VDC, is it getting there? Are the output devices getting their power rails? How about C13 and C32? Are they charged up?
        All the NFB does is report back to the input. There is no output to report, so the op amp amplifies the input to the max trying to compensate for the lost signal at the output. The output of the op amp is not being amplified by the power stage. You are not blowing fuses, so the MOSFETs are probably OK.
          ....what about DC levels through the amp. What is at TP 7,8,9,10? The two input transistors of the power amp on page 2 need +/-16VDC, is it getting there?
          TP7 and 8 are at 5.5 and -5.5V. The chart calls for +5.5 at 8, which I assume is a typo?
          The other sides of R32 and R33 measure 16V and -16V.
          TP9 and TP10 show zero volts with no signal. The chart calls for a 5.5V offset.
          The MOSFET's are all getting their rails.
          The + side of C13 measures 62V and the - side of C32 measures -61V.
          R52 and C16 measure good.
          -Erik
          Alameda, CA USA
            We have met the enemy and he is ours
            Found the problem.
            Ray had the right idea with it possibly being a shorted output.
            The gol-durn "startup pop" relay that has messed me up so many times on CrAmpegs was the problem.
            The contacts are shorted together: I pulled it and measured zero ohms between the poles (and the wiper of course).
            My favorite replacement source for these is derelict computer monitors, but I think I'm gonna stock up....
            Thanks for the help, gentlemen!
            -Erik
            Alameda, CA USA
              Ampeg B2 Relay problems
              I'm having a similar problem with my Ampeg B2 Combo where it occasionally will trip my house circuit breaker when I turn it on. After that, it will usually turn on but somtimes will not produce any sound (no audible relay click after power is applied). Other than that it plays fine. However, it's always seemed to have a problem preventing the turn on/off thumps. I'm thinking this all points to the relay circuitry. Any suggestions on what to look for when I open it up?
              - Steve
                Hi Steve, welcome to the forum. This thread has been dead for two and a half years. Start a new thread and you will get better response.
                casinolevant levant casino
