this amp had numerous problems...i've sorted all of them out except that the drive channel doesn't have as much gain as it should (compared to other stage and studio lead amps i've played). i can't find the schematic (100 watt stage lead...not stage lead II). the studio lead (50 watt version) schematic was available on this forum...the design is similar, if not identical, but some of the component values are different. anyway, the components in the vicinity of the volume/gain/master controls all seem to check out...but something is still amiss. i though the diodes on IC5, or the IC itself might be the problem, but they all meter ok. any ideas where the lack of gain is coming from? here's the studio lead schematic again...i'd appreciate someone posting the stage lead schematic if they have it. thanks!
Studio Lead[1].pdf
Studio Lead[1].pdf
