I have a Ruby Reverb Tank from a Rocktron Amp that has a slipped spring.
Basically - the ferrite bead is no-longer joined to the wire that connects it to the output transformer end. Nothing is broken - and I can easily slip the brass-tube at the center of the ferrite bead over the connection wire (it just won't stay there).
I don't know if this is a mechanical connection, solder connection or glue connection that let-go and I can't seem to find any support.
Rocktron support - while prompt - doesn't have the answer either.
Does anyone have any input on this? Yes, I understand a replacement can be had for $30USD - but this seems like a relatively straight-forward fix.
Photos at
http://www.mikesheppard.net/gallery....folder=gallery
Thanks,
Michael
Photos at
Thanks,
Michael
