This el34 jcm style build (similar, but not exact) has been my obsession for over a year now, and i finally got it to a place tonally where i felt there wasn't one detail that wasn't good to perfect. Then i made a big mistake. After all this time it was a slop fest from infinite soldering and unsoldering of parts, so i decided to clean it up. Lifted the board, cleaned up all old solder and made it tight and clean, tho still looked like WW2. It sounded fine till i swapped out a couple parts that i realized should be a different value. Then it started sounding horrible. It sounds like there is a lot more gain but only in the very top of the high end, and the harder you hit it the worse it gets. It's a nasty high end distortion that sound like you recorded to tape and set the channel 3 times too high. A spitting staticy hi end distortion thats hardly noticable at all on the low strings. I swapped every single cap including PSU caps, (except main can) most resistors, checked all voltages and bias,checked OT and choke, all solder joints of course, replaced all tubes, replaced or checked every pot, disconnected NFB, and other things i can't think of right now i'm sure.
i realize this isn't something anyone will likely be able to help me with just from this description considering how much i've already checked. But at this point i'm desperate and don't know what else i can do. I have thought to build a new one, but this one already cost me $600 in parts and i'm not thrilled with the prospect of making spending another 6 bills. So if anyone has any suggestions as to what i might look at next i'm willing to try anything at this point. Thanks.
