Roland JC-77 noisy Chrous OFF mode
  • Roland JC-77 noisy Chrous OFF mode
    Roand JC-77
    The following symptoms appear only when
    the Chrous switch is set to Chorus OFF.
    Crackling, popping,rumbling noise
    This noise is not affected by either a
    input volume increase (instrutment) or
    an increase of the JC-77 volume control.
    It is also not affected by any other
    control i.e. treble, bass, middle reverb
    etc. This noise also modulates from nearly
    non existent to annoyingly loud. If the
    amp is set out in a cold envoirnment the
    noise will not be present until the amp
    warms up. Obviously heat related yet the
    amp must be at below normal room temperature
    to indicate the heat issue.
    In other words when the amp is in either
    Chorus "Manual" or Chorus "Fixed mode there
    is no problem whatsoever. As a matter of
    fact this is a very quiet amp other than
    this Chorus OFF mode noise. The amp had a
    bit of hiss and hum but I went through the
    amp and or re-solder every connection
    to see if a bad connection was the issue.
    Well it was not but it sure made the rest of
    the amp quiet when I put it back together.
    Cleaning the chorus switch had no impact
    on the issue.
    I will venture to guess that this issue
    has something to do with one of the delay
    (Chorus) IC's as the clean signal passes
    through it. But to be honest I am not able
    to read the schematic to the level that I
    can understand the actual path of the clean
    signal.
    Thanks for you consideration.
