Hi, I got some troubles on an up to now trusty Carvin BelAir:
the Drive Channel suddenly became weak and farty, while the Clean Channel was ok, so I replaced all the (rather old) tubes with new 12AX7 WB Sovteks and EL84Ms for power amp, rebiased the amp, and it worked fine for some hours. On next rehearsal after switching ON, the Clean Channel was totally weak and the Drive Channel had become weak and hissing again. I checked and cleaned all the jacks (Input, FX, Footswitch),tube sockets and pcb connectors/wires, but it did not fix it. Also I tried different new tubes( JJs, EHs, GTs) for no bettering.
Any ideas what parts to check next, any similar experiences with those Carvins?
Thanks for help
Zouto
Thanks for help
Zouto
