After the amp is warmed up and when I'm playing hard or turn on the tube driver pedal while playing hard this amp will cut out, no sound. When it cuts out while I'm in the clean channel, the red light for the drive channel will come on and burn dimly. If it cuts out while I'm in the drive channel then bright drive light will go dim.
While the amp is in this cut-out state with no sound, I can press on either one of the 330 Ohm 5 Watt ceramic screen resistors with my guitar pick and the amp will work until I release pressure.
So it seems there's a bad solder joint that breaks contact when things are heated up.
Can anyone explain what these resistors are doing and how I can perform a repair? When the signal from my guitar and pedal is strong does it cause these resistors to get hot? I don't know what a screen resistor is supposed to do. Are there any other parts in this amp a novice like me should check out?
The preamp tubes are GT ECC83, power tubes are 6L6GC.
Thanks.
Thanks.
