Cold bias on Epiphone Triggerman
  • Cold bias on Epiphone Triggerman
    Well what I thought was a blown speaker upon further inspection is bad crossover distortion from what i imagine to be coldly biased output devices.
    i don't suppose amyone has a schematic so I can try to adjust the bias eh?
    Any one else work on one of these?
    Epiphone TM
    I do not see an adjustable bias.
    Time to check transistors.
      Bias, or maybe one side not working.
        Oh hey, I never checked back so I wanted to thank you guys for the help and Ted for the schem.
        Looking back it looks like R318 1k in parallel with R35 10k was actually a 2.7k resistor.
        I had lowered the 10k to another 2.7k and that helped alot.
        Thanks again.
          Thanks again.
          Thanks a lot, before changing R35 to 2.7 K my amp had a buzzing sound. Now it's clean, my R318 is 1 K.
          By the way do you have any idea for removing the hiss from the dsp effects? The flanger and chorus are unusable because of this.
          Richard,
