problem with Bluesbreaker voltages - help...
    You can run a lead over to a ground point. Remember you are not grounding something in the signal circuit, you are only grounding a shield.
    What is the voltage across the standby switch when it is OFF? If you put a cap there, it better bave a higher voltage rating than what you find there.
    Pops are not necessarily from the switch arcing. The tubes are hot, and when teh switch is flipped there is a large current surge as caps fill up and voltages rise quickly in the circuits. The tubes amplify that into a pop.
    Enzo,
    in standby the switch has 360v on it. in 'play' mode it's got 418v.
    It's been suggested that I put a 0.047uF cap from the cold side of the switch to ground but there isn't a convenient ground point where the standby switch is located.
    Would a thermistor/surge-guard cure the popping if I connect it between the hot side of the switch and the B+ feed to the circuit?
    HTH - Heavier Than Hell
      Little caps generally go across the switch contacts, not to ground. I do not generally "fix" standby switch pops, since they are normal and a fact of life.
        Cheers Enzo,
        The amp doesn't seem to be popping at the standby switch now anyway so it's not even an issue anymore.
        I'll keep that info in my files.
