I acquired a silver face twin reverb that was making some truly horrific noises. Valve 3, the reverb drive 12at7 got very hot quickly so I figured it was a good place to start debugging. Sure enough, replacing it fixed the noise, but the new tube got hot as well. The B+ measured 439-440 (spec on this amp and the ab763 is 440) but the cathode voltage only measured 4.85 (spec is 6.0 on this amp and 8.6 on the blackface). The cathode resistor only measured 280 ohms, and to my surprise, there is no bypass cap.
The spec on a MV twin is 470 ohm for the cathode resistor with no bypass cap, but on the AB763, it shows as 2200 and there is also the standard 25-25 bypass cap.
First step, I want to replace the resistor pronto before it burns up another tube. Can I go with a 2200 without the bypass cap, or should I go with a new 470 until I can get a cap? I figure I can get a resistor at ratshack to hold it over until I can place a parts order for a more substantial overhaul. Not having the cap just reduces the gain on that stage right? If I need more gain (seems like it has more PLENTY of reverb such that I could spare some) I can always run a 12ax7 in that stage correct?
Longer term, my plan was to swap out a few of the components to "blackface" the amp. After finding one resistor that is so far off in value, and realizing that I have no way to measure the caps other than to check for shorts, I am a little weary of everything in there. I am thinking of getting an entirely new main board and all new resistors and caps. I figure the parts should be between $50-$75 but the kits I see are more than double that. Am I missing something? The B+ and filament supplies are spot on, the pots all work and are quiet (except the MV which I bypassed while I had the chassis open anyway) so I don't think I need to touch the power supply or replace the tranys or anything else. Again, am I missing something I should be worried about?
I am not looking to invest too much since it is much bigger LOUDER (it has a pair of Celestion Vintage 30's!) and cleaner than I generally prefer and I may just fix it up and sell and then build a Mission 5e3 or similar with the proceeds.
Thanks.
Thanks.
