Replaced Power Caps but Now No Clean Channel
  • Replaced Power Caps but Now No Clean Channel
    I just replaced my power caps with JJS. Both tubes light up and the gain channel(B) works great but the clean is dead. As soon as I move the gain(pre amp) pot on channel A the two clip leds on the pcb light up and there is a shot noise but no sound from the guitar at all. Any ideas? There is no sound from the effects loop so it must be before the pre-amp.
    jcm 900 4500
    Check your work. You may find the problem. Check solder joints. Make sure all caps are in correctly. Make sure your tubes are all seated properly. All connects plugged. Etc..
    sigpicCharlieP
    (2)Peavey VK 112 2008
    Fender SuperSonic 60W 112 2010, 5E3 Build Mojotone
    Met. Red LP Gibson Robot 2008 Tronical Tuners
    Faded Cherry LP Gibson 2007
    Fender Strat HSS LSR S1 2008 Pearl
    Fend FSR Telebot Dlx Candy App 2011 Tronical Tuners
    Gretsch G5120 2007 Black
