I recently purchased a second hand Frontman 15G amp and it has been working OK.
However, from time to time it will just start humming, even without anything plugged in and then after a while the hum will dissappear.
The hum is not affected by volume or tone controls, however, if I touch both the AUX input sockets and the metal part of the handle bar the hum goeas away. Touching the input socket and the handle bar does not affect the hum - only the AUX.
I've opened the case and inspected the PCB but could not notice any cracked solder or any other issue with components including filter capacitors. The metal part of the handle bar is connected to the earth connection of the AC socket via heat sink, so it looks like some problem with the ground.
Any ideas on what is causing this issue and how to fix it?
