Biasing Chinese EL84's
  • Biasing Chinese EL84's
    Using this Schematic,
    http://www.axlguitars.com/schematics/AA-AK-40.pdf
    At TP14 through TP17 It says I should have 20mv on each.
    Is that setting a little "cold"? (I was filling my head with Biasing videos over at
    Eurotubes dot com.)
    The ones that are installed are Chinese "May-pop's" so I was thinking about
    installing a different set to change the tone.
    Also, I can't seem to be able to find the biasing trim pot in the schematic.
    The main PCB has one though.
    Edit: found it A-5
    Last edited by SmogFighter; 04-08-2010, 07:10 AM. Reason: found bias trim on schem...
    "Humor is the best alternative to serial killing." - Chuck H
    "Smile and wave boys, smile and wave....." - Skipper the Penguin (Madagascar)
    "I thought it was 30 minutes of greatness wrapped in
    an hour of SUCK!" - Scott Kurtz describing Aliens vs.
    Predator
    Sure enough, if you bias them too hot, they may pop.
    20mA per tube seems reasonable, we recently had several threads on biasing, and they came to the conclusion that it's really not super important.
      "Also, I can't seem to be able to find the biasing trim pot in the schematic.
      The main PCB has one though." It's called "BIAS 1" & sits betyween R110 & R111 on the schem.
      Yes 20mA sounds cold, but if that's what the manufacturer specifies I'd stick to it, plate voltage is quite high. If you want to try more like 30mA per tube (10.8W-ish) invest in some Russian/Sovtek/Reflector military EL84/E84L, they'll take it easily at 13.5W max dissipation.
      When biasing up Pro Jrs/Blues Jrs etc. there is a tangible difference between mid 20's & 30mA/tube in terms of tone, I would aim for 30mA and reduce to the point before the tone goes cold/sterile.
        I just noticed...
        You guys are referencing mAmps... The Schem says mVolts...
        Would TP7 be my plate voltage measuring point?
        Thanks for your help,
        Raul
        Predator
          Same thing. The measuring resistors are 1 ohm, so 1mA through them gives a 1mV reading on your meter.
            Thank you for pointing that out!!
            I'm a
            Predator
              Another Question...
              Since the Amp is rated at 40w and has 4 el84's they are expecting @ 10w per tube?
              so to do the math 10w/350v = 28.6mA =100%
              70% of 28.6 = 20.2mA
              what is the rated wattage of a typical el84?
              on this Data Sheet, it shows the wattage output @11w with an Anode Voltage of 250v
              and @17w with an anode Voltage of 300v.
              But after looking at my Anode (plate) voltage, shouldn't I expect higher
              wattage?
              Predator
                Idle power dissipation is not the same thing as audio power output.
                  I took some measurements today...
                  tp7 (Plate/Anode Volts) = 342vdc
                  tp14 (V5) =25ma
                  tp15 (V6) =21ma
                  tp16 (V7) =25ma
                  tp17 (V8) =06ma
                  So, where do I look for a problem?
                  Predator
                    Tube V8
                    Tube V8 is not conducting.
                    Swap it with V7 & see if the issue follows the tube or stays at the socket.
                    If it follows the tube, shes a no good.
                    If it stays at the socket, check the screen & grid reistors.
                      Thanks...
                      I will try that after dinner tonight.
                      Ok, after dinner, I swapped V8 with V6 (Right next to each other) and this is
                      what I got:
                      tp14 (V5) =27ma
                      tp15 (V6) =11ma (suspected bad tube)
                      tp16 (V7) =27ma
                      tp17 (V8) =48ma
                      Then I swapped V6 with V5 (again, right next to each other) and:
                      tp14 (V5) =11ma (suspected bad tube)
                      tp15 (V6) =26ma
                      tp16 (V7) =68ma
                      tp17 (V8) =26ma
                      Which shows that it follows the tube. it also shows that it stresses it's
                      companion tube (evens and odds paired).
                      SO, I'm off to purchase a new set of tubes.
                      Thanks for all of your help, Gentlemen.
                      Predator
                        Wacky... looks like two of them are matched, but the other two are way out.
                          New Tubes!!!!
                          After a new set of JJ's, everything balances out.
                          tp14 (V5) =25ma
                          tp15 (V6) =26ma
                          tp16 (V7) =25ma
                          tp17 (V8) =26ma
                          I decided that while I'm at it, I can change out the preamp tubes as well.
                          Amp sounds great and is considerably louder at any given volume setting.
                          Thanks All,
                          Raul
                          Predator
                          casinolevant levant casino
