Peavey M2600 Mark V no audio
  • Peavey M2600 Mark V no audio
    Had fuse with alum foil on it when I got it, put a 5 amp circuit breaker in place. With no speaker load it will not pop breaker. With speaker load on A channel OK. Pops breaker when Channel B has load. I can have amp on and just push Channel B jack in and as soon as it makes contact it blows a blue spark and pops the breaker. No audio on A or B except when I plug A in it will make a small pop. This amp has no signs of ever being opened up.
    I have a factory paper Peavey schematic
    Peavey M2600
    It sounds like Ch B output section is blown.
    Put a meter on Ch B output, without a load.
    I'll bet you will find a very high dc voltage.
      you are right
      44.2 volts. I have the B channel unpluged from the output board. Channel A doesn't have any voltage on output, but is quiet no audio. I am sure this has been asked before, but what is the best way to check to3 type transistors in circuit ? This amp has 4 67376(2n5630) per side plus a 5332 and 5331
        is this normal
        I read 44 volts on the top of all the to3 transistors to ground with a dvm
          Peavey 200H
          Yes, I would expect +42 volts on all the collectors.
          The top half of the circuit the collector is at +VDC.
          The bottom half the collectors are at output.
          It appears that the top half is full on.
          I would diode check every transistor on the output board.
          Check all of the resistors also.
          Checking NPN transistors:
          -DVM on Diode Check.
          -Red Lead on transistor Base.
          -Black Lead on transistor Collector.
          - Should read something like .540
          -Black lead on transistor Collector.
          -Should read a lttle less than Base/Collector.
          This circuit & schematic is great for troubleshooting!
          Peavey was nice enough to indicate static voltages.
          If you check the output transistors in circuit be aware of the Base/Emitter resistors. A diode check reading is not possible.
          Check the power supply + = Vdc & the + - 15 volt rail.
          Take out Q1 & Q2 to check. A shorted Q2 will tie the output rail high.
          Thanks for the correct schematic, Enzo
            Well, we ought to give him the right schematic. Oddly enough, his amp doesn;t have a Q1 or Q2. It starts with Q3. Q1 and Q2 were on an earlier version across the input volume control as limiters. They were eliminated for the later version.
              Thanks Enzo
              That is the schematic I have. I emailled Peavey about all of the transistors in the amp.
              I made a dumb mistake. I had power on it while checking voltages while talking on 2 meters and crossed the leg of a 5332 to the heatsink. Pop goes the circuit breaker. Now it pops everytime I turn it on. I have a cs800 that is in the parts pile I might just use those parts if the factory stuff is worth more than the amp.
              Thanks for all the help, I will do a better job of testing from now on. I really enjoy this site and all the info. Just getting back into working on stuff I have gathered up is real fun. Retired with too much time on my hands
              Tomorrow I have 2 100watt 6 channel Shure Vocal masters to check out. While waiting on parts for the Marshal
