I also tried swapping out the power tubes for another pair, same symptoms
Fender DeVille 212, low low power
The speaker is plugged into the right jack, OK, but did we test the speaker? Plug the speaker into some other amp. Does it work OK?
Have we decided which half of the amp has the problem?
PLug the guitar into the FX return. Does that sound clear out the speaker, or low and crummy?
Plug the guitar into the input out front, and connect the FX send to the input of some other amp. Does the FX send sound OK coming out the other amp, or does it have the problem. No point in checking voltages all over the preamp if the problem is in the power amp, and vice versa.Education is what you're left with after you have forgotten what you have learned.
those fenders have an IC after the pre-amp stage
yes. an IC. that comes from the reverb recovery stage
They usually short and burn after a tube failure or some mystical intervention
Check it and replace it.
I saw the same problem on a blues deville i had here.
Customer brought the amp
minutes later (of use and testing)
bam, low power, crackled sound..
Check for U2 an TL072 Dual OP-Amp.Last edited by Lee_ranaldo; 04-17-2010, 07:17 PM.Hearing Is Believing
Ok. Speakers tested fine.
Plugged the FX send into the input of another amp. Sounds plenty clear, volume control works. Is is safe to say that the pre-amp is OK?
Plugged the guitar direct into the FX return and it sounds quiet and distorted. Master volume still doesn't seem to have any effect on the volume or sound at all, just a small amount of signal passing through.
if i remember correctly the FX send signal comes before the suspicious IC i mentioned earlier.
that's why u get a clean signal if u send the pre-amp output to another amp
but when u plug a signalp into the power amp in , it sounds distorted
because the first thing that signal sees is the U2 TL072 OPAMP that is burnt
Just replace that TL072 opamp! :PLast edited by Lee_ranaldo; 04-25-2010, 07:26 AM.Hearing Is Believing
Costs little to find out. But I woulod point out that when teh FX loop is NOT in use, the signal path does not run through either side of that IC.Education is what you're left with after you have forgotten what you have learned.
If you read what Enzo posted, the IC is not in circuit when the FX loop is not used. So it doesn't matter if the IC is ok or not until you get the original problem solved, which appears to be in your power amp.
Did you ever try changing the driver tube?
Do you have a voltmeter? Have you checked the voltages in the power amp and driver stages?
Try cleaning the extension speaker jack switch contacts.
If you are checking the plate resistors at V3 (pins 1 & 6) you just need to measure the voltage at the tube pins, should be within 15v of each other (see Devilles schem at Fender.com). If one of the pins has no voltage then the resistor that feeds that pin is open & needs replacing.Last edited by MWJB; 05-10-2010, 02:46 PM.
