Hello,
I have two Marshall Valvestate 15 amps.
The first amp, the sound would cut out occasionally;but then the amp would begin working again in a few minuites.It would work for fine for 2 or 3 practice sessions which last 1-1.5 hours each without a problem.Also, sometimes the sound would sound weak, but this simptiom was rare, most of the time the sound would just go out and come back on in just a few minutes.
When the amp does not have sound, it is powered on(has a low hum from the speaker),the sound just goes out.
Sometimes, I would wiggle the guitar input cord and the sound would begin again and I would hear a scratchy sound.
However this does not help anymore.
I am not sure wiggling the cord helped to start with, it is just something I did naturally to make sure it was plugged in to the input jack. When on sound occurrs I hear a hum from the speaker.
The reason I bought the second vs 15 is because of the problem of no sound, from the first amp.......Well guess what?
The second amp has the exact same problem, no sound, a low hum from the speaker and sometimes the amp will come on and begin working! Can you believe it!
Is there anyone who can help me with this?
Thanks, James
Thanks, James
