Introducing a post overdrive tone circuit
  • Introducing a post overdrive tone circuit
    Hi amp guru's!,
    I need some straightforward advice regarding a circuit I've hopefully attached. http://users.tpg.com.au/9876/Bench%20Circuit.JPG
    I'm introducing a post overdrive tone circuit to my amp's overdrive signal. I have cut the pre master amps' PCB circuit path and need to confirm exactly where I introduce the input signal from my amp to the new circuit, and additionally where I output it.
    I'm a little stumped because the diagram indicates what appears to me to be two possible input paths from the 13k Zsrc (one input path pre all three 100k pots (bass treble & mid) and another past the mid pot direct to R5.
    Then the signal appears to be output from a point between both R4 & R5?
    Is this correct?
    Thanks in advance.
    Input at the top, ground at the bottom, output between R4 and R5.
    -Mike
      Thanks heaps defaced.!!
      casinolevant levant casino
