I am attempting to fix a Line 6 spyder II Head. Everything lights up...No sound. Initial inspection showed that both TDA7293 amps were burnt and 3 traces broken. I cleaned up the board and repaired traces and installed two new audio amps. Upon powering up, a small pop and a small wisp of smoke. The amp had sound from the left channel but not from the right. I removed the board to check for visible signs of scorching. I saw none so reinstalled to check the voltages. I got as far as seeing 45V and -45v on the end pins of the TDA's and my probe slipped and contacted another leg on the right channel amp and it went off like a pack of firecrackers..Whoaaa! By the time I got the power off, the light show had traveled to the left side amp. Jeeesh! Stunk up the shop as well as fried both amps...again.
Any suggestions?
My plan is to clean up the board again and CAREFULLY re-install another pair of amps. I am afraid by now that there are other components that are compromised? Any Help, suggestions?...Please!
Any suggestions?
