I've got a 1484 (2 x 6L6) that I've had for several years now (my first tube amp at that). It's been very good to me all things considered. Sounds great. Everything works (though the reverb sure is lacking life).
Well, I've got a couple of other amps in the stable taking care of my main needs, so I finally get the chance to do what I can to give it back a portion of all the joy it's given me.
I'm a novice, though I've done my best to educate myself as much as I can. I know how to discharge capacitors, and how to stay relatively safe while working on an amp.
Ok, onto the amp.
6 tubes in the preamp. 4 12AX7's, and 2 6 6CG7's. All tubes are ORIGINAL. This might very well be the source of any "issues" the amp has (though is sounds great to me), so if I'm just a cheap tard that needs to go buy some tubes, feel free to let me know I'm an idiot.
So the first thing I wanted to check was plate voltage. This amp doesn't seem to have nearly as much gain as I've heard these things crank out (and I play LOUD), so I wanted to start there. Turns out I'm a bit low just about everywhere.
Most of the lower voltage preamp plates are spec'ed around 100V, and I'm measuring between 70-85 in most cases. I know that's not too far off, but what also concerns me is that the higher voltage plates are spec'ed at 225V, 215V,205V, and 160V. I know those aren't "high", but they're all at least 50 volts bellow spec.
There's no listed spec on the heater voltage I can see on the schematic, but I've got an extremely consistent 5.3V across all the heaters in the preamp (measured across the tube, not chassis).
So, am I dealing with old tubes that just aren't drawing the current they should? Or am I looking at old caps that are dry'ed up? I don't see any visible leakage from any caps, and no bulging. That being said this thing IS circa 65' or so.
I haven't checked the power tube voltages yet. Saving that for tomarrow. My lack of knowledge of which pin is which makes me weary without a pin readout in front of me.
Ok, so that's that. Any advice is welcome.
EDIT: Oh, I'm not sure how much this matters, but at the location I'm working on it, the wall AC jumps between 109.8-110.2VAC.
Ok, onto the amp.
