Trace Elliot AH250 - Starts to spark after 30min
  • Trace Elliot AH250 - Starts to spark after 30min
    I've just laid my hands on a Trace Elliot AH250. It's seems to be doing quite ok at first. But at half a hour it start to spark.
    If there's anyone here that have experienced this behavior or that have repaired a Trace Elliot with this... condition I would really appreciate some tips on where to look for gnarlys.
    Where do the sparks come from?
      Oh... Sorry for my imaginative way of describing the noise. There are no sparks flying. The amp starts to pop and make sparking noises after some 20 - 30 minutes.
      I think I'm going to gut it and see if the filter caps are bad. The thing is, I really don't have any experience tinkering with solid state amplifiers. That is way I posted this thread.
      Cheers!
        I've seen bad transistors cause funny noises like this. They were little TO-92 ones, part of the driver circuit in a MOSFET hi-fi amp. They ran very hot by design, and eventually started to degrade.
        But it could also be a bad resistor or cap. Not likely to be the large filter caps though: if those were bad, the amp would hum and sound rough and distorted. It wouldn't cause popcorn noises.
          Isolate the problem. Does it still make noise whith ALL controls at zero?
          ANY control that has ANY effect on the sparking sound is after the source of the sound.
