This is killing me....
switching from clean to lead channel, there's a loud thump/pop. Going back is almost nothing. Switching from front panel pull switch - footswitch not even connected, but if used will also replicate the symptom.
I know relays can emit some noise, and this series is renown for it, but this is obtrusively loud, not a little pop in the background. Enough for the rest of the band to look at me as if to say "what was that.."...
It occurs with no signal, and occurs before volume pots ie; volume(s) on zero silence the amp and also the noise.
I've re-soldered all joints from V3B coupling cap forward to ground and all around relay.
There's no DC on the signal or reverb tracks to/from relay.
Coil volts pre/post are a nice 7.99dc.
No stray dc between tracks although I can't get right in under relay.
I need some help/ideas from the tech guys.
Especially to deduce if it's noise from the coil getting into the signal, or ON the signal side, like a cap suddenly charging/discharging..
Eg; if it's the coupling cap suddenly discharging as it goes from being shorted to ground to now connecting to the lead master pot (and is the schematic drawn wrong in that relay connections section?), how to prove and also how to rectify??
thanks for all thoughts..
Dave
Dave
