is there a difference between a NE5532N and a NE5532 chip?
  • is there a difference between a NE5532N and a NE5532 chip?
    anybody know? i need to replace a NE5532N, i can get a NE5532...is this a straight swap?
    i found these:
    http://www.xs4all.nl/~ganswijk/chipd...sr/ne5532n.txt
    http://www.xs4all.nl/~ganswijk/chipd...usr/ne5532.txt
      One is in a plastic DIP and the other is a ceramic DIP? WHich doesn't matter.
      Look for packaging differences. A surface mount will not make you happy when you try to install it on a through hole board.
      Otherwise, any 5532 dual op amp will do. Think of it like a 6L6. All the extra letters don't mean much when asking if it will work in the circuit.
        thanks enzo!
