good day people
i hope you maybe able to help me repair this big beast,
the power amp is working ok and i have cleaned the send and return sockets, i had to replace R 111-110-116-117 as i was not getting my + - 23 volts now the preamp heaters work and the chanel switching lights work,
i have replaced all the valves (tubes) for known working ones and have replace the high voltage caps, and have checked resistors on the preamp board for open or short circuits.
after scratching my head for a while i have noticed that q6 seem to be shorted with 14 volts on each leg and and i have no volts on q1-q4-q12 and cr9. i think i maybe in the right ball park now , but not sure weather to replace these now or if some other componant may be causing these to mall function. sorry q1 also seems to be shorted. thank you in advance ... blobby
