Hi
I was hoping for a little help with this one, anyone know how to get a schematic for the bass 350 SWR redface amp?
or how they power the fan, I did a little test this morning.
I removed the 24V fan and tested with a PC power supply 12v the fan is not "bad" it spun with the computer supply.
I could not see any voltage being applied to it in circuit.
IT is the same size as a 12V computer fan, I was just looking for
a way to fix this quickly as this is a guy with gigs coming up fast.
The amp is fine I think the driver circuit has failed somehow
I was tempted to make my own 12v rail and use the PC case fan
anyway thoughts and Ideas appreciated.
This amp has a "fan defeat" switch, perhaps I should read that again
does that mean its still based on thermal temp until the fan will go on?
This guy says it never went on, and he is concerned about it.
He also mentioned he wants to be able to kill the fan for recording.
I guess I am wondering if the fan will engage with the amp cold
based on the switch, or if there is more to it than that.
Steve
Steve
